Yup it's fine.
https://linustechtips.com/topic/1391912-power-supply-enough/#findComment-15127024
2 minutes ago, ClassicWhite said:
Does that yupp include if I use all of its cores?
Yes, you can even overclock if you want.
CPUs and GPUs are a lot more efficient than they were 10 years ago.
https://linustechtips.com/topic/1391912-power-supply-enough/#findComment-15127030
30 minutes ago, ClassicWhite said:
I got 2070 and recently bought 5900x and would want to know if 750W is enough for the setup or do i need more?
750W what?
If it's a 750W is something like this:  https://www.amazon.in/Frontech-PS-0011-Gaming-Efficiency-Computer/dp/B09BQGS2P9/ref=sr_1_6?keywords=750W&qid=1638137056
or this:  https://www.amazon.com/KDMPOWER-MI-X8775CD-Quiet-Gaming-Supply/dp/B07DTNKJW4
Then the answer is "no".
https://linustechtips.com/topic/1391912-power-supply-enough/#findComment-15127071
