Hello! So i have issue with fps in some sort of games. I have RTX 3060 Ti and Ryzen 5 3600.
In Rust i get around 40-65fps (Medium Settings) 1080p
Warzone: 70-80fps (Medium Settings) 1080p
Sea Of Thieves 70-90fps (Medium Settings) 1080p
Battlefield 2042: 20-40fps (Low settings) 1080p
Far Cry 6: 40-50fps (Low Settings) 1080P
Can someone help me figure out what the issue could be? Thanks and have a good day!
https://linustechtips.com/topic/1391757-low-fps/
Youre playing 5 of the most CPU bounded unoptimized games in the world, if im being honest. Also, this spec is incomplete, we gonna need more to make any conclusion.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1391757-low-fps/#findComment-15126111
Lower settings or upgrade the gpu.
(additionally first check cpu usage on each core, maybe you also need a cpu upgrade,  although that cpu should be good for 99% of games)
I don't totally disagree,  however I got like 170fps+ in warzone at ~70% cpu usage on a few cores... it wasn't stable 170fps, but it never dropped under 120, and I do believe that's just the nature of unoptimized code, ROTTR was the same for example until they fixed dx12 (for me) so I just locked it (warzone) to 120, never dropped a beat. Of course if op would lower settings according  to their hw and be content with 60fps there probably wouldn't be a problem in the first place...
Dunno about the other games as they're exactly the kind of game I would only play for a large sum of money (500$/hour and we're talking) because i don't really have time to waste with trash like this otherwise.  = )
-Scott Manley, 2021
https://linustechtips.com/topic/1391757-low-fps/#findComment-15126324
