Okay thanks
It would be just controlled depending on the CPU temperatures and if you want to control that fan using EasyTune you would control the CPU fan option. :)
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/139124-case-fan-in-cpu_opt/#findComment-1855120
I don't think it would be controlled without it's 4th pin, would it?
Actually it will. The 4th pin will allow it be more accurate but mobo will still use same amount of power to it as it will for CPU cooler fan. They are meant to be used ie. coolers with 3 fans. Thats why. My mobo lists them under one controller.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/139124-case-fan-in-cpu_opt/#findComment-1858137
Oh okay I didn't know that, well my 1st fan is controlled seperately because it's a different fan
https://linustechtips.com/topic/139124-case-fan-in-cpu_opt/#findComment-1858824
