This isn't necessarily  a new build per se, but i have been trying to find a better solution to have 2 computers sharing 4 monitors.  I currently have 2 docks and a usb switch and 2 keyboards and mice.  What I can do right now is:
1. use one specific computer with everything, all 4 monitors and both keyboards and mice.
2. use half on one and half on the other.
what I want to be able to do is what i can do now, but also be able to use all on both computers while still being able to split between the 2.  so here is my wanted scenario:
1. computer a uses all
2. computer a uses 1 keyboard 1 mouse and 2 monitors while computer b uses 1 keyboard 1 mouse and 2 monitors
3. computer b uses all
Any input on the best route(preferably with as little parts needed) would be greatly appreciated.  Also, if this is not the right place for this post, PLEASE point me to where I should post.  I didnt really see a better place than here.
TIA
https://linustechtips.com/topic/1391108-2-computers-4-monitors-setup-help/
TIA
I don’t have much.  Maybe a little.
I take it you want a 4 wide desktop instead of mirroring. (you might not I suppose.  I don’t know the use case) The only way I know to do that is with a kvm switch with 4 monitor ports.  Might be possible with software kvm. Pixel count and refresh rate of the monitors involved could matter.  I don’t know.  Bandwidth thing. I haven’t heard of a hardware kvm with that many ports but that doesn’t mean it doesn’t exist.  Sounds expensive though.  One would want to take note of the KIND of ports on a hardware switch.  It sounds like software would be preferable over hardware because fewer cables and boxes on the desk.
You could buy bi-directional Displayport switches, if your monitors and video cards have displayport connectors. Here's an example : https://www.amazon.com/Angusplay-DisplayPort-Switch-Bidirectional-Splitter/dp/B089SLDDZZ/
You could get 4 of these and just press the buttons to switch monitor from one computer to the other whenever you want.
If you're up for a bit of do-it-yourself you could open the cases of those and solder a couple of wires where the select button and maybe where the two leds are and bring those to a separate box with your own buttons  and leds (ex make a button that changes all four at the same time)
As for keyboard and mouse, a simply kvm switch would do the job...
-> Moved to Peripherals
F@H
GPD Win 2
