Budget (including currency): total budget. 1100 but prefer lower (taxes)
Country: USA
Games, programs or workloads that it will be used for: Rocket League, Apex Legends, Valorant, Fortnite, Cod Vanguard, Halo Infinite, Forza Horizon 5, and 3d designing software.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): already have the ryzen 5 5600x and 3060. I’m buying a 144hz monitor.
I just need some help reducing or getting parts for cheaper, thinking of replacing the motherboard for a cheaper one, 10 dollars less would be preferred. Any tips or another motherboard for 10 dollars less? (You can replace any part besides the ones that I already bought.)
https://pcpartpicker.com/list/yy4RLP
https://linustechtips.com/topic/1389685-help-ples/
Country: USA
The Gigabyte B550M Aorus Pro has been on sale for $100 pretty frequently on Newegg.
the pc guy
https://linustechtips.com/topic/1389685-help-ples/#findComment-15111649
