So I want to get a new psu, since my old one was always constantly turning off for no real reason. I don't really want to spend too much on a power supply, however, so I need some tips. Say if there is enough connectors for everything I need, does that mean it is enough power? If not, here are my specs:
MB: hp elitedesk 800g1 sff
PSU: Undetermined
Cpu: Xeon e3 1220 V3
Cooler: Stock
RAM: 8gb ddr3
gtx 770 2gb gddr5
2tb 7.2k rpm HDD
256gb (I think) PM851 samsung SSD
5 ~1200 rpm fans
I was thinking if a 550w psu would be enough.
Thanks!
https://linustechtips.com/topic/1389299-power-supply/
You'll need adapters - your computer doesn't use a standard PSU. Are you still using the stock SFF case as well?
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
https://linustechtips.com/topic/1389299-power-supply/#findComment-15108776
34 minutes ago, svmlegacy said:
A 550 W unit would be plenty. Make sure to get a decent quality PSU.
It's possible that there's a difference between nVidia's spec sheet and real world application, but they do recommend a 600W PSU for this card.  I recently purchased a 600 W 80+ Gold rated EVGA supply, but it was non-modular.  Only $65 USD, though.  You'll pay around a little less than double that for a fully modular supply.
https://linustechtips.com/topic/1389299-power-supply/#findComment-15108805
gtx 770 consumes up to around 180 watts
that cpu and motherboard won't consume more than 100 watts
even a decent 500w psu should be fine. Just make sure it can supply a decent amount of watts on 12v output (you'll want at least 400w on 12v), which is used to power the cpu and video card. Some power supplies advertise a higher wattage amount, but a part of that wattage is "locked" on the 5v and 3.3v outputs, which are barely used in your system.
https://linustechtips.com/topic/1389299-power-supply/#findComment-15108835
