Hi,
A new corsair LGA1700/1200 block has 110 fins [old one had 60], Heatkiller PRO IV has 78, Bykski/Barrow blocks [the good ones, not the bottom cheap], have 48-60
How important is the fin density inside the CPU block? Will this XC7 RGB PRO  [no reviews yet] block offer better cooling versus others?
Thanks
https://linustechtips.com/topic/1388832-how-important-cpu-block-fin-density/
Assuming the fin length and depth is comparable across the brands/models. Wouldnt put too much though into it. No need to chance 1-3c based off other peoples results.
3 hours ago, WickedThunder86 said:
More Fins= More surface area= Better thermals.
All else being equal, this. However there are a myriad of other factors which mean that it's not very good in isolation as a metric for determining performance.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
Isn't the IHS size of Alder Lake quite a lot bigger than with previous chips? So you obviously will have a higher total fin count even with the same fin density.
Generally speaking: more surface = more heat transfer = better.
But you also need to get your water inbetween those fins. The smaller the gaps the higher the restriction. The deeper the gaps the harder it is to get your water down through the gap (-> jet plates -> higher restriction).
Use the quote function when answering! Mark people directly if you want an answer from them!
So should i go for the new 110 fin Corsair XC7 RGB PRO that was made for Adler lake instead of using old 78 fin Heatkiller IV Pro?
I have 2 rads, 360GTX and 480GTS and dual pumps, DDC build into the reservoir and D5 outside
I meant factors between blocks, rather than within the full loop.
I'd say that's the best idea since the IHS is a bit larger and you want the cold plate to cover as much surface as possible on the IHS. That's exactly why your regular AiO designed for AM4 or LGA1200 is not a good fit for Threadripper on TR4 even though there might be a suitable mounting kit.
Alderlake die size isn't that large so the Heatkiller IV Pro fin area would already cover it.  Don't bother replacing blocks.  The IHS being larger is somewhat irrelevant since most of the heat transfer happens through the IHS directly in contact with the die.
We're at the point where really all CPU blocks that are good (which the Heatkiller still is) are more or less the same.  Having crazy high fin density just leads to a really restrictive block without much thermal benefit.  That's why a block from 2015 still hasn't been "upgraded".
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
You're mixing IHS and die size in an improper way.  Threadripper used a lot of substrate surface area because of 4 discrete silicon chips.  So yes it led to a larger IHS but it was also a huge silicon surface area which is really why you needed larger fin areas to cover.  I don't think there's any single die chip that exceeds the fin area of a waterblock, mainly because it isn't economically viable to fab a piece of silicon that large with how defect density works.  (I think the 3080/3090 are probably the largest.  Maybe Xeon Phi or Itanium were similarly huge but no one here uses those.)
Alderlake is basically the same size as anything since Ivy Bridge.  The IHS changing dimensions is due (probably) to pinout requirements for IO like DDR5 and not because of the actual silicon getting larger:
Intel Core i9-12900K Alder Lake Delidding Video Lays Bare Thinner Die And A Gold Surprise
Ivy bridge:
Delidded Ivy Bridge 3770k @ 4.6GHz (update 4.8GHz), 30 degree temp drop -  YouTube
And meanwhile Zen 3 (which BTW doing it like this fucks over your profit margins because you're paying 2x more just for the silicon fabwork and also they're paying it to a contractor who needs to make a 20% profit vs. Intel paying it to themselves):
s9eXvPp_MP2kwYy1v6PUyKKwNF7f_G65OjGhsmPwOZM.jpg?width=1024&auto=webp&s=b86b5d6ddd94cb5ac4a6284fe8b770651350f8c7
