Ram timings Help!
Go to solution Solved by Chris Pratt,
Yes. Looser timings will hurt you in memory bound applications. Things like Adobe suite and Blender are more CPU bound than anything else, though, so you may not see much difference there. Gaming on the iGPU is going to suffer, but you were already suffering with just 3200MHz. You really need faster RAM for integrated graphics, since performance is heavily dependent on the system RAM there.
Even if you buy the same kit from the same manufacturer, there's no guarantees they'll be compatible. Manufacturers very often change out the dies without even updating the SKU. Honestly, the whole concept of upgrading your RAM later by adding two more sticks is a joke. There's almost always issues, if for no other reason than you're putting more stress on the IMC. You're almost always better off just buying a new kit in the capacity you need, and just flip the old kit on the used market to recoup some cost.
Hello, I used to only have 1 HyperX fury 16gb 3200 and 1 Kingston Fury 16Gb 3200 Running at D.O.C.P at it's true timings 16-18-18-18-36. I am well aware that even though they have different names and model numbers, the Kingston Fury is exactly the same Ram, just rebranded because they Kingston let go of the HyperX Branding.
Now I upgraded my PC by adding (2) Kingston Fury 16Gb 3200 which is packaged as 16x2gb kit. Now whenever I turn on D.O.C.P which automatically sets the proper 16-18-18-18-36 timings, My PC would not boot , or if lucky, it will boot but will hang without a moment's notice and will need a hard restart.
What worked for me was Setting everything in Auto (D.O.C.P. turned off), set the RAM speed to 3200MHz then set the voltage to 1.35V which sometimes sets the timings to 17-17-17 or sometimes even 22-22-22, honestly I'm just happy to be running it at 3200MHz rather than 2400MHz
Now my questions would be, will there be a difference in both Gaming and Productivity given that I don't have a dedicated GPU on these RAM timings? (I use Adobe programs and also Maya and Blender)
Also, is there any way to fix this?
Mobo: Asus Prime b550M-K (Bios rev. 2423)
Cpu: AMD Ryzen 7 4750G
GPU: Built-in APU
RAM: 64GB (1xHX432C16FB3A/16 (HyperX Fury 16x1Gb 3200) 3xKF432C16BB1A/16 (Kingston Fury 16x3 3200)
OS: Windows 10 Pro
https://linustechtips.com/topic/1388394-ram-timings-help/
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1388394-ram-timings-help/#findComment-15101981
DOCP/XMP settings are rated for 1 kit per system. When you mix kits like that (even if its the same model ,it doesnt matter), you risk breaking stability at its rated setting. Adding the new kit to another memory channel is usually more forgiving (the one you did at the start) but mixing to the same memory channels is not.
Desktop benching:
https://linustechtips.com/topic/1388394-ram-timings-help/#findComment-15102121
oh btw you can try fix this by tuning voltages and timings yourself. Just like overclocking memory in general.
Desktop benching:
https://linustechtips.com/topic/1388394-ram-timings-help/#findComment-15102694
