Hello all gurus.
I have just "built" a new machine, added memory and disks, on a Intel NUC11PHi7.
Did install windows 11 pro from scratch and apart from graphics nvidia driver, it seemed to be all drivers in the Iso, but
testing it for real load I often use Jam Software and heavyload, to check how hot it will be.
That software complain, virtual machine so "host being overloaded inadvertently"!
Then tried to disable vm/hyper-v and to my surprise, not possible in bios (v065 latest)
Did core isolation off, System\Device Guard registry, cmd admin "bcdedit /set hypervisorlaunchtype off",
and still get "host being overloaded inadvertently"..
1 will I gain performance doing this, doing streaming, ndi, video mixing and can not have varying performance?
2 If so, how to disable virtual machine as I can not in bios?
Thank you
Geir Otto Molstad
Oslo
Norway
https://linustechtips.com/topic/1388121-vbs-and-virtual-machine/
