Weird GPU problem
ShoByte
Zotac 2070 super twin fan
5600xt
gaming edge wifi B550
650watt seasonic FX focus plus
Also tried in multiple machines/monitors/cables
Tried multiple drivers
This happens even with a clean install of windows(tried 2 times on 2 different computers.
DDU doesn't work
Tried flashing the bios of the GPU
When I launch any DX11 game haven't tried DX12, the GPU will boost to its max then drop to 375 and freeze. Then, it'll unfreeze and boost again. Repeat until it crashes. So, it's go, freeze, go with more of the freeze then crash. If I run any openGL program the is no crashing at all and no freezing. Not 100% positive on performance but there  is no crashing.
I'm extremely confused on this one. Can a GPU be broken for one api and not others?
5600xt
DDU doesn't work
does your gpu have 2 pcie connectors and if yes are both plugged in or only 1?
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
both are def in.
forgot to mention, if I run furmark then a DX11 program the DX11 program will not crash. Soon as I close furmark the DX11 will act like what I said in my first post.
