hard drive questions
By
Zob
in Storage Devices
in Storage Devices
Solved by kirashi,
9 minutes ago, Zob said:If i use a sata splitter for sata 3, (6gbps) would it affect my hard drives drastically? like damage them, ruin them, or will it just work with lower speeds
If you're talking about using some kind of PCIe-based SATA HBA or RAID card, you're usually pretty safe, but can you clarify what you mean by "SATA splitter"?
srrrx ·
Posted in New Builds and Planning1 -
rayu ·
Posted in New Builds and Planning4 -
Ordinaal ·
Posted in New Builds and Planning2 -
sumgreenday ·
Posted in Displays8 -
6
1
