Badly need advice
Solved by Electronics Wizardy,
3 minutes ago, Quickstrike said:Also, should and is are two different things. I just have to open the thrash bin on a colleague's PC and find a boatload of data.
How would putting the workstations on a rack affect this? Just tell the users to store data on the nas shares, not on their pc. If you want to enforce this you can use redirected users folders for their home files are on the nas, and they don't have permissions to store on the local PC
4 minutes ago, Quickstrike said:We don't need that much, maybe 20 terabytes, but it has to be highly available. A VM might do it if we have enough network and disk access to limit bottlenecks.
Yea a simple tower server should do this. Have a vm for sql and a file server.
What speed is your network?
