Just wondering if this RAM works well with haswell.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_538_913&products_id=21887
If not any recommendations?
Thanks is advance
Intel i5-4670K, Asus Maximus VII (z97), 16gb Kingston, Asus Gtx 780, Fractal Design Define Mini, 250Gb Samsung Evo, Corsair CS650M
        Yey dis meh Pc
https://linustechtips.com/topic/138710-ram-help/
Yeah it should be just fine
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/138710-ram-help/#findComment-1848957
        Yey dis meh Pc
https://linustechtips.com/topic/138710-ram-help/#findComment-1848963
The Gskill kit has 16gb
yeah sorry i read the one i linked wrong my bad and i fixed my post
https://linustechtips.com/topic/138710-ram-help/#findComment-1848973
No problem just wondering is 8gb of RAM sufficient for light editing aswell as gaming?
        Yey dis meh Pc
https://linustechtips.com/topic/138710-ram-help/#findComment-1848980
yep, i think it is better to buy less but better ram, rather than more bad ram (not saying that, that ram is bad)
https://linustechtips.com/topic/138710-ram-help/#findComment-1849003
What would you recommend?
        Yey dis meh Pc
https://linustechtips.com/topic/138710-ram-help/#findComment-1849012
one sec let me try to find something on that website
https://linustechtips.com/topic/138710-ram-help/#findComment-1849019
what is your max budget?
https://linustechtips.com/topic/138710-ram-help/#findComment-1849024
150 but preferably under. Just 8gb's
        Yey dis meh Pc
https://linustechtips.com/topic/138710-ram-help/#findComment-1849039
http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_218&products_id=17729 or
http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_218&products_id=21781
depends on what color you want there are other but i just linked my two favorites
https://linustechtips.com/topic/138710-ram-help/#findComment-1849055
        Yey dis meh Pc
https://linustechtips.com/topic/138710-ram-help/#findComment-1849064
Thanks for the help
yep, anytime and if you have any other questions feel free to message me
https://linustechtips.com/topic/138710-ram-help/#findComment-1849077
