This is a much better build. Ignore the warning about the Hyper 212 being incompatible, it is.
PCPartPicker Part List
CPU: Intel Core i5-12600K 3.7 GHz 6-Core Processor  ($299.99 @ Best Buy)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler  ($43.00 @ B&H)
Motherboard: Gigabyte Z690 GAMING X DDR4 ATX LGA1700 Motherboard  ($229.99 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($81.99 @ Newegg)
Storage: Mushkin Enhanced Pilot-E 500 GB M.2-2280 NVME Solid State Drive  ($57.99 @ Amazon)
Storage: Western Digital Blue 2 TB 3.5" 5400RPM Internal Hard Drive  ($44.99 @ Amazon)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case  ($89.99 @ Amazon)
Power Supply: Super Flower Leadex III Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Newegg Sellers)
Total: $937.93
Generated by PCPartPicker 2021-11-08 11:21 EST-0500
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1387039-build-thoughts/#findComment-15091003
21 minutes ago, FanOfLinux said:
You should probably go with a 12600k. I would highly recommend against using windows. You should be using something decent such as Linux, or Freebsd.
I think I just had a stroke reading that
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1387039-build-thoughts/#findComment-15091028
That's just completely unnecessary, and quite frankly, ridiculous. Windows is just as good. Linux has its own issues, especially for the stated use cases (i.e. gaming and business). Linux gaming has come a long way, but there's still significant issues that need to still be resolved. The Steam Deck should create some momentum there, but we're not there yet by any stretch of the imagination. When it comes to business apps, there's a significantly high likelihood that the OP relies on probably multiple applications that will not be available to Linux. Not all of these apps are trivial to replace, either. For Word, sure, you can just use Libre Office or something. For something like accounting software, though, there's *very* high lock in, and switching applications would be totally impractical.
There's lots to like about Linux, and it's great you're so enthusiastic about it. However, it is not the second coming of Christ. It's just an OS with its own issues and problems just like any other OS. Windows is better than Linux at many things, just as Linux does some things much better than Windows. Saying you shouldn't use Windows at all is just ignorant.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1387039-build-thoughts/#findComment-15091033
Total: $937.93
I would like to stick with AMD as that is what I'm more familiar with
https://linustechtips.com/topic/1387039-build-thoughts/#findComment-15091039
Go for a 5600X, not a 5600G. You don't need the iGPU if you have a dedicated graphics card already, and you're trading lots of performance for that iGPU. Actually, you might even consider a 5800X. It's not strictly necessary for what you're doing, but it's seen a price cut since Alder Lake launched, and it would give you plenty of overhead to grow into. For $300, it's a stupidly good deal.
https://linustechtips.com/topic/1387039-build-thoughts/#findComment-15091050
I would go with a B550 board instead. B450 might work, but it also might not. There's a better chance of less head aches with the B550 board.
I would also go with a 1 TB NVME drive instead of a 500GB NVME and 1TB HDD. The large capacity drives are normally faster and have better endurance than their smaller counterparts.
You also don't have to buy a windows license to use windows. You can run it unlicensed just fine
https://linustechtips.com/topic/1387039-build-thoughts/#findComment-15091073
The 12600K is brand-new, and performs quiet a bit better than a 5800X while being cheaper. But if you are sure, then this would be way to go:
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  ($386.66 @ Amazon)
Motherboard: Asus ROG STRIX B550-F GAMING ATX AM4 Motherboard  ($178.99 @ Amazon)
Total: $973.60
Generated by PCPartPicker 2021-11-08 13:04 EST-0500
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1387039-build-thoughts/#findComment-15091240
Extra case fan is for the rear of the case. Since you already have a gpu, go for the 5600X instead. I wasn't really sure what your budget was though.
https://pcpartpicker.com/list/z6hm4d
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($309.00 @ Amazon)
CPU Cooler: Noctua NH-U12S redux 70.75 CFM CPU Cooler  ($49.95 @ Amazon)
Motherboard: MSI MPG B550 GAMING PLUS ATX AM4 Motherboard  ($144.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($63.97 @ Newegg)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive  ($64.98 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Newegg)
Case Fan: Phanteks PH-F120SK 50 CFM 120 mm Fan  ($13.99 @ Amazon)
$896.85
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1387039-build-thoughts/#findComment-15092031
