Kraken G10 issue
Go to solution Solved by Darthvieuda,
Forgive me, it was as simple as the plate not coming into contact with a section of the gpu, I had to swing the mounting bracket around to the next point (contrary to the instructions) in order to get all four sides of the plate evenly touching the gpu. Thanks for the fast storming session fellas. Idle temps are now at 22 and much more favorable. Time to test out some games!
So I have installed an NZXT Kraken G10 on my EVGA GTX 770 and it works fine, temp at idle says 33 which I found a bit lackluster, but the real kicker is when I try to boot up a game. The screen will go black (monitor shuts off) and the PC reboots. I put the stock cooler back on and the games worked fine, no issue. Any ideas at all? This is the second time I have used the G10 and the first run went off without a hitch. Really scratching my head on this one. Where do I start?
https://linustechtips.com/topic/138681-kraken-g10-issue/
Okay, what have you attached to the g10 first of all? Second of all, its doing that due to it not recognizing any fans or cooling, which you can fix by making it think the fans are on by ghosting it, I don't know how but I know you do that. (I THINK)
Diamond 5 in League :)
https://linustechtips.com/topic/138681-kraken-g10-issue/#findComment-1848382
Sounds like you didn't have good contact with the graphics card and it shut off to prevent over heating. Make sure you get the thermal pads and paste applied correctly. Or just your vrm is getting too hot, it's a bad problem with the kraken, which I why I opted to stay on my stock cooler after I had planned on getting one.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/138681-kraken-g10-issue/#findComment-1848386
https://linustechtips.com/topic/138681-kraken-g10-issue/#findComment-1849058
