New here and need Help!
Go to solution Solved by Avocado Diaboli,
7 hours ago, RetainedVelocity said:
because hearing aids will not work as it is a brain problem not a ear problem.
A quick Google search brought up that hearing aids with active noise cancelling exist. I'm not going to recommend a specific type or brand because I'm not a medical professional, I don't know what your precise requirements are and I'm not knowledgeable enough about them to know how far you can dial in the cancelling effect to suit your needs. But the tech is out there and you should probably bring it up to at least the one audiologist that had some experience with your issue.
Hello All!
I am a new member to the community and have a bit of a strange request. I hope this is the right place to post this as it is tech related but in an off topic kind of way. I have pretty bad ADHD and one of my issues is with auditory processing. The TLDR of the issue is basically if there is any amount of background noise, there is a good chance anyone talking is going to end up sounding like the parents from the peanuts cartoons. I have gone to audiologists to try and correct this issue, but they have scratched their heads for the most part and said I was fine. I finally found one who had experience with this issue, but he could not help because hearing aids will not work as it is a brain problem not a ear problem.  This is where I think that some people on here can help. When I tried a buddies air pods pro in the transparency mode, I noticed I was able to understand people a bit better. I think the external mics were dimming the background sound a bit, and thus making it easier for me to understand people. If you understand how this mode works or just an understanding of earbuds with transparency mode on the market, it would be great if you could let me know so I can try and get this issue fixed. I want to try and figure this out both to make my life easier and to spread the word to others with issues similar to mine. I hope this is not an inconvenience to you guys on here. Thanks!
https://linustechtips.com/topic/1386426-new-here-and-need-help/
And now a word from our sponsor: 💩
ℑ𝔣 𝔶𝔬𝔲 𝔬𝔫𝔩𝔶 𝔫𝔬𝔱𝔦𝔠𝔢 𝔭𝔢𝔯𝔣𝔬𝔯𝔪𝔞𝔫𝔠𝔢 𝔭𝔯𝔬𝔟𝔩𝔢𝔪𝔰 𝔴𝔥𝔢𝔫 𝔶𝔬𝔲 𝔥𝔞𝔳𝔢 𝔞 𝔰𝔱𝔞𝔱 𝔠𝔬𝔲𝔫𝔱𝔢𝔯 𝔬𝔳𝔢𝔯𝔩𝔞𝔶 𝔞𝔠𝔱𝔦𝔳𝔢, 𝔶𝔬𝔲 𝔞𝔯𝔢 𝔪𝔢𝔯𝔢𝔩𝔶 𝔩𝔬𝔬𝔨𝔦𝔫𝔤 𝔣𝔬𝔯 𝔭𝔯𝔬𝔟𝔩𝔢𝔪𝔰 𝔱𝔬 𝔟𝔢 𝔲𝔭𝔰𝔢𝔱 𝔬𝔳𝔢𝔯. 𝔗𝔲𝔯𝔫 𝔬𝔣𝔣 𝔱𝔥𝔢 𝔠𝔬𝔲𝔫𝔱𝔢𝔯 𝔟𝔢𝔣𝔬𝔯𝔢 𝔞𝔰𝔨𝔦𝔫𝔤 𝔣𝔬𝔯 𝔥𝔢𝔩𝔭 𝔞𝔫𝔡 𝔰𝔢𝔢 𝔦𝔣 𝔶𝔬𝔲 𝔰𝔱𝔦𝔩𝔩 𝔫𝔬𝔱𝔦𝔠𝔢.
ᑐᑌᑐᑢ
https://linustechtips.com/topic/1386426-new-here-and-need-help/#findComment-15087099
Ok sounds good. I have been digging around on Google for a while but I feel like I need some more technical info to go back to the doc. Thank you very much for the reply
https://linustechtips.com/topic/1386426-new-here-and-need-help/#findComment-15087541
