Hello, I want to upgrade the storage capacity on my custom built PC.
The MOBO is: ASUS Z170-AR, and I currently have 2 SSDs and 2 HDDs connected via the SATA cables. TLDR: Can I add any M.2s onto it without any issues?
Longer version:
I believe that this MOBO can support up to 6 SATA connections.
My MOBO also has an M.2 slot, so I was about to purchase an M.2 when I realised that there are two versions of the M.2: SATA and NVMe. Along with that, I spoke to a friend of mine who claimed that some M.2s disable SATA connections. Attached below I added an image of the MOBO (in blue) writing: "SATA6G_56." So, does inserting an M.2 disable SATA connections 5 and 6? Does it completely disable all of the SATA connections? What's going on?
In my BIOS, I also have the option to swap between "SATA Express" and "M.2." It's currently set on SATA Express. The booklet also talks a little about it shown below.
I am new to all this M.2 stuff so I have no idea what's going on... Please help!
PS:
From what I understood: NVMe is a faster version of M.2 that may not be compatible with some MOBOs. Can mine support it? If it can, will the SATA interface cap it to SATA speeds (6Gb\s)?
This is the current build I am working on:
>>>> The $2500 ($1900 US) Desktop <<<<
>>> Old Build <<<
LAST UPDATED: 30-September-16 / 05:38PM (Sydney Time)
https://linustechtips.com/topic/1384727-m2-confusion-help/
4 minutes ago, FakeKGB said:
Installing an M.2 SATA SSD in that slot will disable SATA ports 5 and 6, yes.
You cannot use an M.2 NVMe SSD in there, it will not work.
Hello! Thanks for the response!
One last clarification: What's that BIOS thing about with the option to change between "SATA EXPRESS" and "M.2", along with the booklet suggesting that I change something before installation?
>>> Old Build <<<
https://linustechtips.com/topic/1384727-m2-confusion-help/#findComment-15073580
Well I don't know if this goes for your mobo but mine have the limitation where SATA 5+6 is disabled if M.2_1 is occupied. However my BIOS allows me to enable those ports if I take the M.2 down from PCIe 4x to 2x. So half the bandwith. Like yours mine is also Asus so check your BIOS you may have that setting too if you want all those ports.
https://linustechtips.com/topic/1384727-m2-confusion-help/#findComment-15073581
Regarding Crucials Upgrade your System Website it should be able to use NVME... Crucial sells NVME 2280 SSDs for that specific board. *shrugs*
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/1384727-m2-confusion-help/#findComment-15073582
SATA Express was an attempted revision to SATA III that never took off.
I'm not sure exactly what it does, so I'd say install the M.2 SATA drive and if it doesn't show up flip the setting from SATA Express to M.2,
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1384727-m2-confusion-help/#findComment-15073584
Hmm, I don't see the point in getting an NVMe if it wont be able to run at its potential. Might as well get a high performing SATA since it will be the same or very close
>>> Old Build <<<
https://linustechtips.com/topic/1384727-m2-confusion-help/#findComment-15073617
The m.2 slot does support NVMe and mentions no limitation for it.
F@H
GPD Win 2
https://linustechtips.com/topic/1384727-m2-confusion-help/#findComment-15073621
@Kilrahbeat me to it but I was just looking it up, the M.2 slot is definitely NVMe compatible. I can't find confirmation from Asus directly but this motherboard database site seems to say its a full PCIe 3.0 x4 slot as well.
https://motherboarddb.com/motherboards/736/Z170-AR/
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1384727-m2-confusion-help/#findComment-15073626
