Budget (including currency): 600 usd
Country: usa
Games, programs or workloads that it will be used for: minecraft kerbal space program and fortnite 1753743331_Screenshot2021-10-236_10_38PM.thumb.png.ef26c29201b580a33c1f52231f666eb4.png
https://linustechtips.com/topic/1383403-first-pc-build/
If you have room in the budget, get some faster RAM (3600MHz CL16 preferred) and a bigger PSU.  Fast memory is very important for iGPU systems, and a bigger and better PSU would allow you to add a good GPU down the road.
It's a pretty good system, and everything that I would change would just add more cost.
Edit: Be warned that you will probably have to go through AMD's RMA department to get a loaner CPU to update the BIOS of that motherboard. If you can afford the extra $25-30 to get a board with BIOS flashback like the MSI B550M Pro-VDH, do it.
Edited by RONOTHAN##
https://linustechtips.com/topic/1383403-first-pc-build/#findComment-15063376
SN550 ain't good SSD.
You can get better board for same price.
You should get faster RAM.
And there's sale for PSU's, I added Corsair one in list, But there is many 650W PSU on sale for some reason, So you can get very good unit for 65-70 USD.
So, Here's better build.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor ($239.00 @ B&H)
Motherboard: Asus TUF GAMING B450M-PLUS II Micro ATX AM4 Motherboard ($82.99 @ Amazon)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3600 CL17 Memory ($77.98 @ Amazon)
Storage: Crucial P5 1 TB M.2-2280 NVME Solid State Drive ($89.99 @ Best Buy)
Case: Thermaltake Versa H18 MicroATX Mini Tower Case ($54.99 @ Newegg)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($64.99 @ Newegg)
Total: $609.94
Generated by PCPartPicker 2021-10-24 06:03 EDT-0400
https://linustechtips.com/topic/1383403-first-pc-build/#findComment-15063905
Would recommend a more stable system. That motherboard brand is not very good, and comes with a lot of prebuilts that fail.
For some odd reason, the case is only used at that price, on amazon right now. I could link another one, but I usually recommend that one for low budget builds. Used - like new, it should be around that price, maybe a little cheaper.
https://pcpartpicker.com/list/934Y4d
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1383403-first-pc-build/#findComment-15063957
My recommendation...
Motherboard: ASRock B550M Pro4 Micro ATX AM4 Motherboard  ($89.99 @ Amazon)
Memory: Silicon Power 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($53.97 @ Amazon)
Storage: Silicon Power P34A80 1 TB M.2-2280 NVME Solid State Drive  ($94.99 @ Amazon)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($49.99 @ Amazon)
Case Fan: Cooler Master SickleFlow 62 CFM 120 mm Fan  ($4.99 @ Newegg)
Total: $602.91
Generated by PCPartPicker 2021-10-24 09:00 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1383403-first-pc-build/#findComment-15064074
