Trying to daisy chain, but monitors mirror
Solved by Glenwing,
3 hours ago, RockSolid1106 said:Doesn't seem to be the case here. I tried the setup with my dad's HP Elitebook Dragonfly max and it worked perfect. Though, I used Thunderbolt here. So Laptop to monitor 1 via thunderbolt and then M1 to m2 via DP.
It's an old i5-3570 iGPU. I'm doubting the DP version here, which I suppose should be at least 1.2 to be able to do daisy chaining.
The PC is an HP Compaq Elite 8300(NOT an all In one). I've tried looking up the specs but couldnt get the DP version on this one.
Unfortunately Intel 3000 series processor integrated graphics do not support MST.
