Hi guys,
So for my latest upgrades to my system my 620w Seasonic non-modular PSU is simply not enough, I have therefore decided to buy a Corsair RM1000, however my motherboard requires 1 8pin cpu power and 1 4pin cpu power unfortunatly the power supply only comes with 1 split 8 pin connector, could anyone tell me where I could purchase another one of these cables?
Thanks
David
CPU  Intel i7 5820k Motherboard Asus X99-S  RAM  32GB (8x4) Kingston Hyper X Fury GPU EVGA GTX 1080Ti SC2 iCX Case Fractal Design R4 Windowed Storage 500GB Samsung 850 Evo + 120GB Crucial M500 SSD + 2TB Seagate Barracuda + 1TB Western Digital Blue PSU Corsair RM1000 Display 2x Asus VS239HV Cooling  Noctua NH-D15 Keyboard  Corsair K70 RGB Mouse Logitech G502 Gaming Surface Razer Golitahus Extended Speed
https://linustechtips.com/topic/138278-modular-psu-cables/
Hi guys,
Thanks
David
What motherboard are you using?
have you just tried plugin just the 8 pin only from what i have learn is where motherboards have 2 lots of power inputs you only really need to use the 4 pin but i could be wrong
I know it doesn't really answer your question tho  :D
https://linustechtips.com/topic/138278-modular-psu-cables/#findComment-1837285
Thanks for the replies guys, after a bit more digging I found out My motherboard, the Asus crosshair v forumala z,can run on just on the 8 pin EPs, the 4 pin is only added when doing an extreme overclock. As for my components, I am in the process of doing a build log where I have upgraded to a R9 290, with the intention of crossfiring it in the future and moving up to a 8350 or 9xxx series.
Thanks for commenting though guys
https://linustechtips.com/topic/138278-modular-psu-cables/#findComment-1839508
https://linustechtips.com/topic/138278-modular-psu-cables/#findComment-1839509
you still dont need 1000w for 2 290 unless you are running the mother of all overclocks 850w would have been plenty.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/138278-modular-psu-cables/#findComment-1846831
