Multi display performance
So before in the past when I used my laptop and an external monitor I swear it would give me way less performance, but I am not sure if it's because it's mixed resolutions going from 4k on the laptop to 1080p of the monitor or just something with hardware.   So right now I have a 240hz 1080p gsync panel,  is there any performance hits from using a different refreshrate/resolution for the secondary monitor?
https://linustechtips.com/topic/1382588-multi-display-performance/
You need higher bandwidth to push high framerate, but in desktop, the difference is negligible (unless you have a very under powered gpu).
6 minutes ago, Inkz said:
Higher bandwidth of what exactly?
Higher bandwidth of the display output.
1080p at 60hz total bandwidth is around 3Gbps.
at 240hz is 14Gbps
at 240hz is 14Gbps
I mean for desktop it is completely negligible, I have a 10900k and a 2080 Super so for me it's just having the side monitor up for lowering the framerate while streaming games
