Hello fellow LTT Forum users,
I am in the process of planning a new build, here's what I've got so far:
CPU: Ryzen 5 5600x
GPU: ASUS GeForce GT 1030
Memory: Crucial Ballistix 16 GB (8GBx2) DDR4 3000MHz
Motherboard: ASRock B450M Pro4
Storage: Intel 512GB 660p m.2 SSD
PSU: Corsair CV550 80+ BRONZE Certified
I need a case (for about $50-60) to round this build off.
Also, can someone just let me know if I'm making a huge mistake with any of my choices? As I'm really new to this, it would be a big help.
https://linustechtips.com/topic/1382530-need-case-50-60-advice/
Phanteks Eclipse P300A Mesh
You could've gotten a better PSU and B550 for possibly a similar price. If you plan on upgrading the GPU everything should be good, if not just know you will be extremely bottlenecked by it and may even have to set games to 720p low.
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057105
P300a or Phanteks p360a whichever fits in the budget.
As for your build yeah some easy fixes.
For the board get a msi b550 pro a.
Ditch the gt 1030 and get a 5600g it's integrated gpu is basically identical to a 1030.
For ram makes sure you get some 3600mhz cl 16 ram so that igpu is performing at max and beating a 1030.
Skip that ssd it's not good better to just get a solid sata drive like a mx500.
Psu not great not terrible depends on what you want to upgrade to later if it is still usable for that.
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057107
The thing is I am really limited by my budget, I can't really afford to go beyond. As for the GPU, I don't really play that many video games so I dont think it would be a problem
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057114
Ah ok thanks
I was thinking about the 5600G as well but the idea of a seperate GPU somehow really intrigued me. But yeah I will definitely consider it.
Also if I'm not wrong 5600X is better than 5600G right?
About RAM, again I am really limited by my budget and I thought the speed of RAM doesn't really matter that much. But since I dont need to buy a GPU I will definitely go for better RAM
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057121
It's like 1-2% better. Not something you'll notice.
Your wallet will thank you AND you can make other things in your pc better by saving that 130$ ish for the 1030 and about 50$ on the cpu too.
For ryzen it very much so does. BUT speed isn't everything you can have cl 14 2400mhz ram that is faster than 3600mhz cl22 ram because of the much lower cl timings on the slower ram. Hence why I recommend cl16 3600mhz ram as that is common and is a great pairing for ryzen.
You should have plenty of budget by ditching the gt 1030 and getting 5600g to do all of this easily.
Even get a cheap decent cooler in the hyper 212 performance range.
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057142
Hey, so the Ryzen 5 5600G and 5600X cost the same in my region...
And yeah I found a decent 3600MHz CL16 option (G. Skill Ripjaws V)
I dont think I really need a cooler as I'm not gonna do anything that intensive on the PC so
And yeah I can afford everything really easily now, thanks!
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057151
Neat get the 5600g still then basically same cpu but you get a vega gpu in it too that is as good if not better than a gt 1030 saving you a fair bit of money.
Boom perfect
More so for silence reasons. Rather than anything else.
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057166
You should get a 5600G like said above and spend the rest on faster RAM, better motherboard and if you can still spend some also a better PSU. Current PSU is fine but can be much better.
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057192
yeah i was thinking of upgrading my psu too, maybe get like a Corsair RM650 gold certified or something
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057201
5600g > 5600x + 1030.  Saving money and performing better.
Ripjaws V means you're cool, good choice.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057237
Ah that's true
How about the TXM Gold? It's the cheapest at PC Part Picker and only 550W so
TX-M has Japanese capacitors rated at 50C and has no 0 RPM mode. RM has 0 RPM mode, better efficiency and is fully modular. Both are great, but the TX-M should last longer while the RM is quieter. Unless you care about noise I'd get TX-M.
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057246
Ah ok, I'll probably go for the TX-M then
Now I just need to find a motherboard supporting 3600MHz RAM and a case for 200 bucks
Couldn't be that hard
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057347
I think this is a good B550 board...
https://www.amazon.com/ASRock-B550M-PRO4-Processors-Motherboard/dp/B089VY5WVM/ref=asc_df_B089VY5WVM/?tag=hyprod-20&linkCode=df0&hvadid=459728334703&hvpos=&hvnetw=g&hvrand=17938062061246634017&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9010943&hvtargid=pla-923530900937&psc=1
If so, that would leave you $90 for a case, which gives you a lot of options.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057358
1 minute ago, Dedayog said:
Oh yeah, this seems like a really good option for me
One question: Motherboard choice doesn't really affect performance right? It's just the features of the motherboard?
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057362
Mostly features, but for overclocking or high end CPU's you need one with good VRM's.
https://linustechtips.com/topic/1382530-need-case-50-60-advice/#findComment-15057370
