My router (D-Link DIR-816) is not connecting to the internet (the light indicating "Connected to the internet" is not lit). I have directly connected the main line to my pc and it's working fine. But when I connect to the router its not connecting to the internet. It's starting the wireless bands properly. I have restarted and reset many times and everything I could think of but no luck. Is there anything I'm missing?
Any help is appreciated.
https://linustechtips.com/topic/1382007-router-problem/
What device is upstream of the DIR-816?
Have you tried a new ethernet cable?
https://linustechtips.com/topic/1382007-router-problem/#findComment-15053685
What is this "main line" connected to, a box with an ethernet port?  Did your PC just get an IP address and "just work" like when its connected to the router when that was working?
https://linustechtips.com/topic/1382007-router-problem/#findComment-15056131
The "main line"(the line came from ISP) is directly connected to my PC nothing in between. This is working fine for now.
No, I signed in with the user name and password manually from the Dial up settings and then work.
https://linustechtips.com/topic/1382007-router-problem/#findComment-15057002
