Budget (1000-1200):
Country:
Games, programs or workloads that it will be used for:
Other details
PCPartPicker Part List: https://pcpartpicker.com/list/CWxz2V
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($299.99 @ B&H)
CPU Cooler: Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler  ($40.99 @ Amazon)
Motherboard: Gigabyte B550 AORUS ELITE AX V2 ATX AM4 Motherboard  ($189.99 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($75.98 @ Amazon)
Storage: Crucial P2 1 TB M.2-2280 NVME Solid State Drive  ($106.97 @ Amazon)
Storage: Seagate Barracuda Compute 4 TB 3.5" 5400RPM Internal Hard Drive  ($74.98 @ Amazon)
Video Card: PNY GeForce GTX 1660 6 GB XLR8 Gaming Overclocked Edition Video Card
Case: Phanteks Eclipse P300 ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: EVGA SuperNOVA GA 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.99 @ EVGA)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($108.78 @ Other World Computing)
Total: $1103.64
Generated by PCPartPicker 2021-10-15 18:42 EDT-0400
any thing i shold change
https://linustechtips.com/topic/1381375-help/
We can't help much if we don't know what the PC is for...
Generally speaking, your current setup is fine, with the exception of that hard drive. They're far slower than even a cheap NVMe SSD, and their durability makes them practically designed for failure & replacement. Chassis manufacturers have already begun obsoleting 3.5" drive cages, so I'd seriously consider a 2TB SSD for now if you truly anticipate that much output, then stack on more SSD storage in the future if needed. I'd also recommend the P400A Digital over the P300, as you'll get significantly better thermals + more room for additions & upgrades.
the pc guy
https://linustechtips.com/topic/1381375-help/#findComment-15048785
Don't get P300, Get P300 mesh.
Don't get Crucial P2, Get P5 instead, It's much better.
You also can have a look at this, It's combo deal for motherboard + GPU, for current market price is good and you'll end up with good Mobo and GPU.
https://www.newegg.com/Product/ComboDealDetails?ItemList=Combo.4363095
https://www.newegg.com/Product/ComboDealDetails?ItemList=Combo.4363083
https://www.newegg.com/Product/ComboDealDetails?ItemList=Combo.4363094
https://www.newegg.com/Product/ComboDealDetails?ItemList=Combo.4350741
https://linustechtips.com/topic/1381375-help/#findComment-15049412
