Budget (including currency): 8950MYR
Country: Malaysia
Games, programs or workloads that it will be used for: School/Coding/Gaming/Animation/Video Editing/Rendering
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): i need every pheripheral
Hi Guys I Already Posted A Thread on this but two things happend
1. Budget Increased
2. Don't Know What two do with that money
Can you guys help me in getting a much better pc for the increased budget.
And.....
I only shop at lazada.com so please give me links from lazada.com
Link to the pc parts list i created: https://docs.google.com/document/d/1T6EE8CR3jpgUB-YklVupW1yiHiVOUF2e6pKqN4KJ0hA/edit?usp=sharing
Pls Mark a solution as a solution, would be really helpful.
BTW pls correct me, iam really stoobid at times.
https://linustechtips.com/topic/1380361-new-build-help/
Upgrading the 6600XT to 6700XT or RTX 3060Ti (raytracing) seems like the best choice for me, you could even cut corners with a cheaper SSD to squeeze out a bit more budget.
Desktop benching:
https://linustechtips.com/topic/1380361-new-build-help/#findComment-15041092
I agree, the gen 4 SSD you aren't really going to notice that much of a difference with performance unless you are gonna do data center operations. I have an Inland Premium in my system, great Gen 3 drive, and it's quite literally 4x faster than my dramless ssd and 7x faster than my WB BLUE 2tb.
https://linustechtips.com/topic/1380361-new-build-help/#findComment-15041109
i understand
iam still going to be sticking with gen 4 because animated files are very huge and big so loading the files will take years on gen 3 thats why iam taking gen 4
https://linustechtips.com/topic/1380361-new-build-help/#findComment-15041168
i can get cheaper gen4 drives like sabrent rocket 4.0 or something like that
https://linustechtips.com/topic/1380361-new-build-help/#findComment-15041169
