Budget (including currency): 500-600 usd
Country: United states
Games, programs or workloads that it will be used for: I am using this build  for Minecraft and basic games nothing too big.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have nothing else nor experience in this.I want minecraft to be able to run 100-200 fps. Thank you to who ever helps me.
https://linustechtips.com/topic/1380337-my-first-build/
for that price, might be best to get something like a used dell optiplex tower, and try and fit the best used/new gpu you can with whats left over.
9020 MT 250$+tax: https://www.ebay.com/itm/274913851081?_trkparms=ispr%3D1&hash=item40022476c9:g:AhcAAOSw6hZgV4TJ&amdata=enc%3AAQAGAAACkPYe5NmHp%2B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSlHY%2FYTip4QFVjNQrCEJt6oxmdFIgVdDx92DFVZp7df91cSOywRSVF%2BqcbYiQCtGaXe%2BoYtR3ZWDzpkIrE1c%2BcYBCld1zMM996TkHcv90ZwFGK26sdfzbqnpyUUuQSGh2LFHUZIKCqzWgflvhUOBNgbV9xUvy3z3BqkpqROYZi%2BL2JOrqxOmN4kZrtld01yOIrFrYmbqhKcrJTHift9HD6B1bgiZ06WQ9VG%2F0hjIsV9T5l1QslsXFLt8rK83du6PAV161Q9MGdgXB3XM6glX%2BlDK8Jc3fWlrnRdmb1vkznlZI4RANn0qVMHgcWQbe2zj6vr340F9rGtLgjtt%2BZqLld4ngVF9Rrv0tqexH%2FQE1lvLbiJrLulJjJSiEuew9aHHnU3Fz4DCKg3Zk3acy6gf9nXnawLBm8VUerdKkHuehvMP%2F3j2dke6JCBxCKO2eHuwX3eGu0sjd5xsHz%2BrgmfrK2XdkZe00WxV8Xn8mqPBf8fu5LlvRRQyLQhRIb11%2BAWMxVCzdeeJRa63E7R0vDeJ2VDdD2qjsD8KLR9Pt6e3NiLe3kyrPvXo8kfJrudaiU2QW7FzyiClXCuVDq5l9fOn1JEWPBc8SN249nFGB8sAO9OE9iuwuzzQGRNbuAZjIF0ah8BXTxIerO0jwjndE3%2FFDT4B4XurvgJHikAwksBamx%2BEy0QEUSkmrRnOvvdK%2BV7U3LGGYe7NHVQkl6zL3LYCWBWYwcyCefvz4kHH1XTSN7om5ysPziFoxR0LyliCyP2slSlIGq7Vjn9fkkATE6XcHKb0Fz34R2t0XDHdyv4RthXTjyW7x6YDMl6LickKZsjQk|ampid%3APL_CLK|clp%3A2334524
wd blue 500gb ssd: 55$+tax(might be better/cheaper options) : https://www.amazon.com/dp/B073SBZ8YH?tag=pcpapi-20&linkCode=ogi&th=1&psc=1
that would leave about 175-275$ for a gpu, could find a 1050ti, or a 970, or a 1070 within that budget on the used market.
there are plenty of combination of storage, tower, and gpu you could play with to get the build where you want, but it should do what you need. just keep in mind that the stock psu might not run all of those gpu options, so i would keep that in mind in case you need to fit a new psu into the budget. building a pc from scratch with that budget can be done, but you will get more bang for your buck building off of a dell prebuilt imo.
https://linustechtips.com/topic/1380337-my-first-build/#findComment-15040947
PCPartPicker Part List
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor  ($239.00 @ Newegg)
Motherboard: ASRock B550M Phantom Gaming 4 Micro ATX AM4 Motherboard  ($89.99 @ Newegg)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($69.98 @ Amazon)
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive  ($89.99 @ Amazon)
Case: Cougar Gemini M MicroATX Mini Tower Case  ($44.99 @ Newegg)
Power Supply: Antec NeoECO Gold ZEN 500 W 80+ Gold Certified ATX Power Supply  ($52.90 @ Amazon)
Total: $586.85
Generated by PCPartPicker 2021-10-11 20:31 EDT-0400
https://linustechtips.com/topic/1380337-my-first-build/#findComment-15040948
Buy a 4th gen i7 Optiplex tower, a new PSU, and a GPU like a 1060.
https://www.ebay.com/itm/234222034858?hash=item3688b89faa:g:tyEAAOSwFnVeuEzo
https://www.ebay.com/itm/274982552614?epid=2167325648&hash=item40063cc426:g:X4UAAOSw25VhZIIG
https://www.ebay.com/itm/203245344122?epid=26032170033&hash=item2f525dd57a:g:Y1MAAOSwOqtf~JGc
https://www.ebay.com/itm/384439466844?epid=6010710210&hash=item598260bb5c%3Ag%3AYccAAOSwTUlhYysV&LH_BIN=1
You can then buy either a molex to 6 pin PCIe adapter, or get a new PSU to throw in the case with whatever money you have left.
You can find all of these parts cheaper on local markets, they're just what I quickly found on eBay
https://linustechtips.com/topic/1380337-my-first-build/#findComment-15040950
