Help With Secure Boot/Windows 11
6 minutes ago, NumLock21 said:Setup is suppose to specify why your system cannot install Windows 11 not that generic error. Try this and see if it does anything or gives more info
Go into bios and reset everything back to defaults the save+Exit
Boot from Win11 setup and see error it gives if there are any
Got both TPM and Secure boot is missing. Then go into bios and enable 1 feature at a time and see if the enable feature disappears from the list of requirements.
Yes it disappears, then back into bios and enable the other requirement and repeat.Still don't work, Re download windows 11, do the ISO version and make a USB bootable drive using Rufus.
Yayyyyyy!!!! It finally worked, currently installing win11. I'll let you know if I run into any other problems.
