-> Moved to Cases and Mods
Depends. RGB connectors are not universal. If the strip uses same physical size, and same pinout (12V,G,R,B), then you can use it. If not, then not. If you use wrong pinout, or otherwise try to force it, you will only break X number of things.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1379697-wall-led-strip/#findComment-15036484
9 hours ago, Ultradragorippe said:
So other words 4 wires RGB header 3 wires the addressable led header?
4-5 wires are rgb and argb can be 3 wires or 4 wires.
https://linustechtips.com/topic/1379697-wall-led-strip/#findComment-15037620
