upgrading computer need help memory
Solved by BobVonBob,
I'd recommend going for 16 GB unless you have a very good reason to get 32. DDR3 is dead, and you won't be able to reuse it whenever you upgrade the rest of your system. 16 GB is more than enough for even a brand new system, and you won't end up spending more than you need to.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
