Budget (including currency): 800$
Games, programs or workloads that it will be used for:  GTA V, Rocket League, Unreal Engine, Adobe Premier Pro
I wanted to build a PC and im not convinced enough that this configuration is what i need
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
CPU Cooler: be quiet! Pure Rock 2 CPU Cooler
Motherboard: Gigabyte B550 AORUS ELITE V2 ATX AM4 Motherboard
Memory: Kingston HyperX Fury 8 GB (1 x 8 GB) DDR4-3200 CL18 Memory
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive
Video Card: Zotac GeForce GTX 1060 3GB 3 GB AMP Video Card
Case: be quiet! Pure Base 500 ATX Mid Tower Case
Power Supply: GameMax GP 650 W 80+ Bronze Certified ATX Power Supply
The GPU is what i already have, thus i spent all my budget on other components.
https://linustechtips.com/topic/1377744-pc-build-need-advice/
So, If you already have GPU, Don't get me wrong, But this is pretty unbalanced and bad build 😞
3600 is expensive, While not being good. 5600X is mostly same price but much better.
CL 18 rams are slow.
Board is expensive for this price range.
Drive ain't good option.
U can get better PSU.
Here is one build if u want RGB.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($289.99 @ B&H)
CPU Cooler: Vetroo V5 52 CFM CPU Cooler  ($29.99 @ Amazon)
Motherboard: ASRock B550 Pro4 ATX AM4 Motherboard  ($134.99 @ Amazon)
Memory: Crucial Ballistix RGB 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($83.99 @ Adorama)
Storage: Crucial P5 1 TB M.2-2280 NVME Solid State Drive  ($99.99 @ Amazon)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case  ($89.99 @ Amazon)
Power Supply: MSI 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.98 @ Amazon)
Case Fan: Phanteks PH-F120SK 50 CFM 120 mm Fan  ($13.99 @ Amazon)
Total: $822.91
Generated by PCPartPicker 2021-10-02 04:48 EDT-0400
Here is second: Only aesthetics changed.
CPU Cooler: ID-COOLING SE-224-XT 76.16 CFM CPU Cooler  ($29.99 @ Amazon)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  ($139.99 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($83.99 @ Amazon)
Case: be quiet! Pure Base 500DX ATX Mid Tower Case  ($99.90 @ Newegg Sellers)
Case Fan: be quiet! Pure Wings 2 87 CFM 120 mm Fan  ($10.90 @ ModMyMods)
Total: $834.73
Generated by PCPartPicker 2021-10-02 04:52 EDT-0400
You should get idea what to look for...
https://linustechtips.com/topic/1377744-pc-build-need-advice/#findComment-15023001
Total: $822.91
Total: $834.73
i am limited when it comes to parts, this is the site where i get my parts from https://www.pandashop.md/ro/
for motherboard what about Gigabyte B550 Gaming X V2
https://linustechtips.com/topic/1377744-pc-build-need-advice/#findComment-15023006
