<-- Moved to CPUs, Motherboards, and Memory -->
How did you find out its fake? Can you post pictures of it?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1376011-help/#findComment-15010978
In the future please make your thread descriptive of the problem so people who have useful info can find it more easily.
Return the CPU to retailer you bought it from, if possible?
I would also like to know how you've reached the conclusion it's fake.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1376011-help/#findComment-15010981
Aaaanddd the OP is offline-
also, are you sure its fake or is it an incompatible chipset?
specs
ASRock B650I Lightning WiFi
AMD Ryzen 7 7700X
KLEVV CRAS V RGB (2x16GB) 6000MT/s out of the 7200MT/s I could be running
ASUS RTX 3060 OC (12GB)
Thermalright Frozen Edge 240 RGB
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1376011-help/#findComment-15010998
