Here is the second iteration of my rig.
The first one was called metallic ice and I uploaded it around two years ago, unfortunately at that time linus tech tips was on Vbulletin that absolutely refused to upload my pics. After a year i decided to upgrade to the NZXT's H440 and H100i plus a fan swap. I was planning to do a full watercooling loop but unfortunately EVGA is being really annoying with their exclusive, non-existent, unattainable waterblocks.
I disassembled the graphics card to change the thermal paste/pads and to clean out the dust that accumulated over the year.
Specification:
  • NZXT H440 White and Black
  • Asus Sabertooth Z77
  • Intel Core I7 3770k
  • 2 x EVGA GTX 680 Classified 4gb
  • 32Gb Corsair Vengeance
  • Corsair AX1200i with white sleeved cables
  • 3TB Seagate 7200rpm (main storage)
  • Corsair Force 3 120Gb SSD (boot drive)
  • Asus Xonar Essence STX
  • Corsair H100i
  • 4 x Corsair AF120 Performance edition
  • 2 x Corsair SP120 Performance edition for the rad
  • 2 x Bitfenix Alchemy White LED strips
post-5785-0-63021900-1397052179_thumb.jppost-5785-0-99147200-1397052273_thumb.jppost-5785-0-98210600-1397052307_thumb.jppost-5785-0-10479000-1397052325_thumb.jppost-5785-0-98401800-1397052378_thumb.jppost-5785-0-08497700-1397052422_thumb.jppost-5785-0-76600600-1397052484_thumb.jp
https://linustechtips.com/topic/137593-metallic-ice-v20/
How u got that side panel for Phantom 410 mate...??
I used a dremel to cut out the window, vinyl wrapped it and then glued the u-channel in. It was actually pretty easy, just make sure to mask the side panel, because if the dremel slips it will ruin the side panel.
https://linustechtips.com/topic/137593-metallic-ice-v20/#findComment-1828206
That looks really cool...good job mate... :)
https://linustechtips.com/topic/137593-metallic-ice-v20/#findComment-1828211
