Budget (including currency): $1200
Country: USA
Games, programs or workloads that it will be used for: Blender, Cinema 4D, Creo, SolidWorks, light gaming
Hey Guys I'm setting up a build for a friend he is going to use is for 3D modeling and some gaming/Editing. The goal is to get the most out of the graphics card while also having some decent CPU power for Creo/solidworks. Heres the link what are your thoughts?
(He already has the 3070 the 1200 is for the remaining parts in the build)
https://pcpartpicker.com/list/VMdrdD
https://linustechtips.com/topic/1375025-build-based-on-3070/
PCPartPicker Part List
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  ($393.99 @ Amazon)
CPU Cooler: Gelid Solutions Phantom CPU Cooler  ($36.99 @ Amazon)
Motherboard: MSI MPG B550 GAMING PLUS ATX AM4 Motherboard  ($139.99 @ Newegg)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-4000 CL18 Memory  ($140.00 @ Newegg)
Storage: Silicon Power P34A80 1 TB M.2-2280 NVME Solid State Drive  ($99.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: NVIDIA GeForce RTX 3070 8 GB Founders Edition Video Card  ($0.00)
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case  ($89.99 @ Newegg)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($88.00 @ Amazon)
Total: $1038.94
Generated by PCPartPicker 2021-09-21 21:50 EDT-0400
https://linustechtips.com/topic/1375025-build-based-on-3070/#findComment-15003592
Total: $1038.94
That build is actually awesome thank you!
https://linustechtips.com/topic/1375025-build-based-on-3070/#findComment-15003629
3600MHz CL18 RAM is almost the same as 3200MHz CL16 RAM, so I would recommend getting that instead. Go for a better SSD too, for sure.
https://pcpartpicker.com/list/vqLwRT
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($267.99 @ Newegg)
CPU Cooler: Noctua NH-U12S redux 70.75 CFM CPU Cooler  ($49.95 @ Amazon)
Motherboard: MSI MPG B550 GAMING EDGE WIFI ATX AM4 Motherboard  ($184.88 @ Walmart)
Memory: G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($119.99 @ Newegg)
Storage: Western Digital SN750 1 TB M.2-2280 NVME Solid State Drive  ($125.99 @ Lenovo)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Best Buy)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Amazon)
$1013.77
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1375025-build-based-on-3070/#findComment-15003654
Country: USA
actually a good list
Though i suggest changing
Cooler to phantom or fuma 2
Ssd to kingston a2000
Psu to msi mpg (not neccesary but save a few bucks)
Cheaper 3200 cl16 rams (3600 cl18 has the same performance as 3200mhz cl16, though i think cl16 is preffered here since no apu)
Mobo to b550a pro or tomahawk (x570 is uneccesary)
5600x to 5800x (prob doable with the money saved)
https://linustechtips.com/topic/1375025-build-based-on-3070/#findComment-15003801
6 hours ago, lee32uk said:
You don't need a 360mm AIO to cool a 5600X. Total waste of money.
He has a budget of 1200...i was trying to use most of that so i went with a high-end cooler.
I do agree with you though...but you should probably put something a little nicer than a hyper 212 on it...
https://linustechtips.com/topic/1375025-build-based-on-3070/#findComment-15004827
A ~$30 cooler like the Arctic Freezer 34 will be fine. The money saved can be better spent elsewhere.
https://linustechtips.com/topic/1375025-build-based-on-3070/#findComment-15005048
