Budget (including currency): $2800 USD
Country: Perú
Games, programs or workloads that it will be used for:  Autodesk Fusion 360 and Inventor rendering, Maya 3D, Lumion, CSP, heavy use of tabs in chrome, Steam games (Mass effect 3, deus ex md, etc)
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  I have a Logitec mouse and keyboard that I still use and hasn't fail me yet plus a Asus zenScreen that will remain in use. But I really need a better PC to render 3D that doesn't need me to close everything but that program and leave it on like that for hours.
I'm upgrading from a IdeaPad Lenovo so no other pieces will be carried over and I want this PC to last me at least 5 years before I need to upgrade it. I have tried assembling a PC with part picker (https://pcpartpicker.com/list/pz9J68) and I want some help with it to know if anyone knows better or more affordable parts that still will do the job. The most important thing is for it to last me a while, I really need it to be reliable as it will be used for work and for gaming.
Edited by Axcl
forgot to add the link
https://linustechtips.com/topic/1374499-mini-itx-build/
You could get a less expensive case
https://pcpartpicker.com/product/wzfmP6/silverstone-case-sstsg13wb
you could opt for a Ryzen 12 core CPU to improve render performance, and go down to a 120mm radiator to accommodate the case size
https://pcpartpicker.com/list/8ZLs9N
120mm radiator in the Sugo SG13 lets you have a longer GPU
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1374499-mini-itx-build/#findComment-14999548
