Need help with my aio, I'm kinda lost with which way my aio pump should place my thermal is not good but I know its because I live in the actic and it gets hot in here so temps  on idle 50 then jumps to 60 and back down, while gaming it can hit 70-80, pump at 100% and same with all 4 fans  and should i change my power settings?
https://linustechtips.com/topic/1373806-help-with-aio/
Got same aio and layout. Shouldn't be an issue which way it's facing. And your temps seem fine if your room temp is really as bad as you say. Only thing I'd try in really bad weather is eco/power saver, it doesn't impact performance as much as you would think but drops temps by a lot
x570 dark hero | 3950x | 6800xt rog hybrid | tridentz 3200 2x16 + 4000 2x16 | 1tb 980 pro, 512gb 970 evo, seagate 1tb wd 5tb | kraken x63 | dark base pro 900 r1 | corsair hx850i
https://linustechtips.com/topic/1373806-help-with-aio/#findComment-14994566
ty for letting me know and my cpu is Ryzen 3700x and eco/power saver i will check it out
https://linustechtips.com/topic/1373806-help-with-aio/#findComment-14994576
Just to say, the 3700x is a hothead. Even when ure good with ur Coolingsolution. The Temps are usually a little higher then with other cpus. i dont know why. But i faced this issue a lot in the past 4-6 weeks when some customers ordered a pc with a 3700x. So yeah, u shouldnt worry this much.
The only things u can try is a repaste, or trying to get higher RPM with ur fans.
Greetings from Germany
https://linustechtips.com/topic/1373806-help-with-aio/#findComment-14995300
ok thanks i did repaste my thermal with an arctic silver 5 and the fans RPM when max hitting  around 1600rpm,  i guess the cpu is  just a hothead then
https://linustechtips.com/topic/1373806-help-with-aio/#findComment-14995403
Yeah, as long as it isn't constantly hitting the max temp of 95°C (203°F) for that cpu, it should be fine.
23+ yrs IT experience
MAIN SYSTEM
Operating System
Windows 10 Pro x64 21H1
Case
Antec Three Hundred Two Gaming
CPU
AMD Ryzen 9 3900X 3.8GHz 12-Core 24-Thread
Motherboard
Asus ROG Strix X570-E Gaming
RAM
G.Skill Trident Z RGB Series 32GB
(2 x 16GB) DDR4 3200 (PC4-25600)
Graphics Card
Asus Nvidia Geforce RTX 2060 Overclocked (Factory) 6GB GDDR6
Dual-Fan EVO Edition
Storage
2 × Samsung 970 EVO Plus Nvme (M.2 2280) SSD 1TB
2 × Samsung 860 QVO SATA III 6.0Gb/s SSD 1TB (RAID1 Array 1)
2 × Hitachi UltraStar HDS721010CLA330 7200RPM SATA III 3.0Gb/s 1TB (RAID1 Array 2)
PSU
Thermaltake Toughpower GF1 850W 80+ Gold
Optical Drive
LG WH16NS40 Super Multi Blue Internal SATA 16x Blu-ray Disc/DVD/CD Rewriter
Displays
HP w2408 widescreen 16:10 1920x1200 @60Hz
HP w2207 widescreen 16:10 1680x1050 @60Hz
Keyboard/Mouse
Logitech MK200 Wired Keyboard/Mouse Combo Kit
https://linustechtips.com/topic/1373806-help-with-aio/#findComment-14996175
