Budget (including currency): around $1,500 USD for the PC
Country: United States
Games, programs or workloads that it will be used for: It will mostly be for gaming. Games like war thunder, enlisted, red dead redemption 2, skyrim, minecraft, and other similar games.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I'm planning on buying the components as they go on sale and try to get on the waiting list for the GPU to avoid the price gouging that's happening. I plan on playing at 1440 and 144Hz.
https://pcpartpicker.com/list/JLWBMv
https://linustechtips.com/topic/1373584-first-pc-build/
Very weird cpu, cooler, and board choice
Why a k cpu but a whimpy overpriced cooler + a non ocable b560 board?
Btw 11600k is the same price as a 5600x so might aswell go for a 5600x instead and get better efficiency + cheaper board
4400mhz cl19 partriot viper is around 120$ so if you actually bother to tune your rams (no they most likely wont run out of the box at their rated speed) then go for that instead, otherwise just get 3200mhz cl16
980 is a decent drive but its just overpriced asf, go for a kingston a2000 instead, ~95$ and has dram cache unlike the 980
P300a is a good case choice but only comes with 1 fan so i def wouldnt pick it anymore, not at that pricepoint atleast, go for a montech x1 (no need to add extra fans), neo air (exhaust fan needed), or focus g (exhaust fan needed), fan wise if you need to add fans go for arctic p12, great value great performing fans, i think they are on par with the more expensive noctua stuff
Psu is ok but kinda eh value, go for a 700w neoeco gold or 750w capstone (if you can find em)
For the love of god do not pay full price for a garbage os, you can get w10 keys for 20$ from sites like scdkey, even has youtuber promos so you can get a discount, you could go ebay keys but those are completely random keys
Im not sure on peripherals sine im not a peripherals guy
¯\_ (ツ) _/¯
https://linustechtips.com/topic/1373584-first-pc-build/#findComment-14992942
I'm just gonna say, don't buy parts over time. If one part is dead, you won't know until you get all your parts and build the system, and by then you may be out of the return window. Plus, sales on computer parts are very weird, and if you want sales, you're gonna need to be very fluid with your parts list, since it's almost always on last gen hardware. If you're gonna wait for a sale, wait till Black Friday, and make the parts list a week before to adjust for the prices at that time, since prices vary so wildly on PC parts.
Out of the parts you picked, none are bad, and is a decent parts list. There are some things that I would personally change, like the memory to 3600MHz instead, the SSD to a WD SN750, buy a Windows 10 key on eBay or just run it with the watermark, and case to a P400a digital, but there are reasons to go with the ones you did.
https://linustechtips.com/topic/1373584-first-pc-build/#findComment-14992949
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($272.66 @ Walmart)
CPU Cooler: Gelid Solutions Phantom CPU Cooler  ($36.99 @ Amazon)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard  ($124.99 @ Newegg)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($72.99 @ Newegg)
Storage: Silicon Power P34A80 1 TB M.2-2280 NVME Solid State Drive  ($99.99 @ Amazon)
Video Card: EVGA GeForce RTX 3060 12 GB XC GAMING Video Card  ($728.88 @ Amazon)
Case: Corsair iCUE 220T RGB Airflow ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($88.00 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($99.99 @ Newegg)
Monitor: Gigabyte G27Q 27.0" 2560x1440 144 Hz Monitor  ($299.99 @ B&H)
Keyboard: Deco Gear DGMECHBRD100 RGB Wired Gaming Keyboard  ($39.99 @ Amazon)
Mouse: Corsair M55 RGB Pro Wired Optical Mouse  ($35.98 @ Target)
Total: $1980.44
Generated by PCPartPicker 2021-09-15 22:21 EDT-0400
https://linustechtips.com/topic/1373584-first-pc-build/#findComment-14992967
