USB Microphone for 20 USD and under?
ToasterBoogaloo
Looking for a USB Microphone under 20 USD, i couldn't afford any XLR mic because i can't afford a mixer
Doesn't have to be fancy, as long it's clear and better than a phone or any cheap earphone mic, i will take it
I live in Indonesia so that might give you some idea, and something like the k669b is beyond my budget
I just wanted to hint to the Logitech headset I just got for around 15-20 € but that is not usb but two audio plugs...
That one has an excellent microphone. Really good.
If that would work for you as well, look up this one:
Logitech H110
I don't know if the usb pendant has the same grade of microphone...
Perhaps this helps.
Cheers
Ang
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
Indonesian here, and i elect you to just forget any mics below K669 price range and use your phone. There are multiple route to this, but the easiest route for me has been the WO Mic app, but i know someone can give me an open source alternative to this.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
I want something to run off from my laptop since my phone is awful and I want to make recordings much easier without transfering data back and forth
