I’m looking to get my pc out of the room and this seemed to be a way. I have a tb3 hub a couple metal tb3 short cables, and a Corning opt. tb3 cable. My test runs have not been successful.
I plug in and turn on the hub, plug in hdmi to hub and monitor, then plug the tb3 cable into my gpu and the hub input port.
If I use a short copper cable everything works fine. The hub light changes from green to blue indicating it sees my pc and my monitor instantly comes awake.
If I use the Corning cable nothing happens at all. The hub light stays green and seemingly never even sees my pc. I’ve replaced the Corning cable as well to make sure it wasn’t a bad cable.
Am I missing something obvious here, or is this just not happening?
GPU - EVGA GeForce RTX 2080ti Xc Ultra Gaming
https://linustechtips.com/topic/1372616-corning-cable-remote-setup/
Does the hub get power from the thunderbolt 3 cable? If it does, the optical cable won't work.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
