My pc wouldn't post this morning after working perfectly fine last night. I couldn't find much info on the code and there was a lot of misinformation ranging from thermal paste to ram. For me, simply changing the graphics card to a different slot solved the issue and my pc posted
https://linustechtips.com/topic/1372546-q-code-68-not-posting/
Is this still a request for help or not?
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1372546-q-code-68-not-posting/#findComment-14984953
Are you asking a question or posting a fix?
What Motherboard are you using? sometimes codes are manufacturer specific.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1372546-q-code-68-not-posting/#findComment-14984956
All AMI post codes will be the same with exceptions of revisions through the years where some where added.
Many post codes are not listed in most manuals. Only because these codes are essentially a reference to the self check process and usually when the pc hangs its just on some random number.
When you want only and strictly error codes, you plug in the diagnostics speaker to find what the error actually is.
I could keep on going, but I'm sure you're aware I had made a thread to help address these situations, but was merged into another post in the stickies and most often times it's just over looked. You can find it in my signature for future reference.
https://linustechtips.com/topic/1372546-q-code-68-not-posting/#findComment-14984998
