Hi, I currently have one fan in my build, but for obvious reasons it gets hot really fast... So I want to buy at least 3 more but I have no idea wich type of fan I need. I want them to be argb and be able to control it like my other fans rgb and case rgb, with a rgb button on the case. Btw, some recomendations? not too expensive pls!
Thank you!
https://linustechtips.com/topic/1371968-case-controlled-fans/
1 minute ago, SuperLeo23 said:
What about this one? Cooler Master MasterFan SF360R ARGB
its more expensive than the fan u said was too expensive.. but
it has less airflow
less pressure
much more noise and motor noise
(i have all 3 fans mentioned i this thread)
https://linustechtips.com/topic/1371968-case-controlled-fans/#findComment-14980587
it has less airflow
less pressure
The one I said was too expensive was only one fan, these are 3. But okay I dont want them to be noisy, thanks
https://linustechtips.com/topic/1371968-case-controlled-fans/#findComment-14980591
https://linustechtips.com/topic/1371968-case-controlled-fans/#findComment-14980649
https://linustechtips.com/topic/1371968-case-controlled-fans/#findComment-14980653
