Pls Help
Go to solution Solved by DontBeSillyWrapYourWilly,
Check all the connections first 🙂 Bump could easily dislodged a 24 pin or CPU 8 pin out of place.
So history, I accidentally bumped my feet to the pc and it shut down by itself, and I tried turning it on again but it wont post anything this time, the msi ez debug led has both the cpu and dram lights on, its not interhcnaging between the two but the two lights are just on, I tried reseating the ram and tried to reset cmos battery(but I think cmos battery doesnt help but I tried it anyway), and also I tried to turn off the power supply switch and turned on the power button so the remaining charge was dissipated but still, no luck, pls help....
https://linustechtips.com/topic/1371861-pls-help/
GPU : RTX 3070 Gaming X TRIO | CPU : Ryzen 5 7600 \ COOLER : Deepcool AK620 | MOBO : ASUS TUF Gaming B650 Plus | RAM : Corsair Vengeance RGB DDR5 16GBx2 6200 MHz \ Storage : Samsung 970 EVO Plus M.2 1TB \ PSU : Corsair TX750M | CASE : Be Quite! Pure Base 500DX Black
https://linustechtips.com/topic/1371861-pls-help/#findComment-14979748
