Hi, I have built a new gaming rig. Everything is fine except, but I don't know how to connect the Thermaltake case fans to my msi z490 motherboard, I want to connect the fans from the case switchboard to my motherboard to control fan speed
which ports or headers do I use. Should it be connected to motherboard ??
https://linustechtips.com/topic/1371855-case-fan-rgb/
What does the manual say?
I would guess there is a cable to go from the "M/B In" to the motherboard.  But since you didn't list any part numbers or system specs,  and I can't tell from the pic what kind of connector it is.  What case?
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
https://linustechtips.com/topic/1371855-case-fan-rgb/#findComment-14990497
The manual does not explain that,
my case is thermaltake level 20 gt
https://linustechtips.com/topic/1371855-case-fan-rgb/#findComment-14991581
I checked, it's in the manual.  your case should of came with 2 different jumper wires, one for Asus/MSI motherboards and one for Gigabyte boards.
https://thermaltake.azureedge.net/pub/media/productattach/c/a/ca-1k9-00f1wn-02_level_20_gt_argb_manual_190617.pdf
Slayerking92
https://linustechtips.com/topic/1371855-case-fan-rgb/#findComment-14991801
