I've had a 4790K for the past 6 years or so, and I figure it's time to move to some newer hardware.  I'm looking into getting a Ryzen 5600X, 32GB of G.Skill Trident Z RGB, and an Asus ROG STRIX B550-F GAMING motherboard.  I'll be combining this with my existing Kraken X61 and an Asus RTX 2080 STRIX.
So the question is, is there some way I can combine all this RGB malarkey into a single program?  I'm hoping to avoid a bunch of programs that have to run on startup.  I don't want any special effects or anything; I just want to press the power button, have it all turn pink, and be done with it.  I will have NZXT CAM regardless of additional RGB software, so that should be able to control the CPU cooler.
Thoughts? Would a different hardware layout work better for the RGB to work together? I'm open to ideas.
Bonus question:  Anybody know if the Trident Z RGB will retain its RGB settings when the computer is in BIOS or booting? It would be nice if it did, but its not like it would influence my purchase.
https://linustechtips.com/topic/1371746-how-does-this-newfangled-rgb-stuff-work/
With the Asus motherboard, you should be able to use Asus Sync for both the motherboard's backlights and the RAM. It's actually somewhat plug-and-play.
Do you have any RGB fans, or are those the only RGB components in the system?
It's entirely possible that I misinterpreted/misread your topic and/or question. This happens more often than I care to admit. Apologies in advance.
珠江 (Pearl River): CPU: Intel i7-12700K (8p4e/20t); Motherboard: ASUS TUF Gaming Plus Z690 WiFi; RAM: G.Skill TridentZ RGB 32GB (2x16GB) DDR4 @3200MHz CL16; Cooling Solution: NZXT Kraken Z53 240mm AIO, w/ 2x Lian Li ST120 RGB Fans; GPU: EVGA Nvidia GeForce RTX 3080 10GB FTW3 Ultra; Storage: Samsung 980 Pro, 1TB; Samsung 970 EVO, 1TB; Crucial MX500, 2TB; PSU: Corsair RM850x; Case: Lian Li Lancool II Mesh RGB, Black; Display(s): Primary: ASUS ROG Swift PG279QM (1440p 27" 240 Hz); Secondary: Acer Predator XB1 XB241H bmipr (1080p 24" 144 Hz, 165 Hz OC); Case Fans: 1x Lian Li ST120 RGB Fan, 3x stock RGB fans; Capture Card: Elgato HD60 Pro
翻生 (Resurrection): CPU: 2x Intel Xeon E5-2620 v2; Motherboard: ASUS Z9PR-D12 (C602 chipset) SSI-EEB; RAM: Crucial 32GB (8x4GB) DDR3 ECC RAM; Cooling Solution: 2x Cooler Master Hyper 212 EVO; GPU: ASRock Intel ARC A380 Challenger ITX; StorageCrucial MX500, 500GB; PSU: Super Flower Leadex III 750W; Case: Phanteks Enthoo Pro; Expansion Card: TP-Link Archer T4E AC1200 PCIe Wi-Fi Adapter Display(s): Dell P2214HB (1080p 22" 60 Hz)
壯麗 (Glorious): Mainboard: Framework Mainboard w/ Intel Core i5-1135G7; RAM: G.Skill Ripjaws 32GB (2x16GB) DDR4 SODIMM @3200MHz CL22; eGPU: Razer Core X eGPU Enclosure w/ (between GPUs at the moment); Storage: Samsung 970 EVO Plus, 1TB; Display(s): Internal Display: Framework Display; External Display: Acer (unknown model) (1080p, 21" 75 Hz)
