Recommended cable configuration for 3000 series cards
Teesul
I have been using an 8 pin connector coming from the psu which is daisy-chained to two 8 pin connectors (1 cable) on my 3080 since early November. I have an ASUS TUF 3080 OC which requires 2x8 pin connectors and a Super Flower Leadex III 850W 80+ Gold which is in the A tier LTT tier list. I have had no issues yet but I was watching Linus' video today with him rebuilding a pc with the verge guy and just found out now that a daisy chain is not recommended. I just researched and apparently the daisy chain is definitely not the smartest choice, could be a fire hazard. I have 2 daisy chain cables that came with my psu, could I plug both into the psu and have an 8 pin plugged into each with the other 8 pin dangling on each cable? Would they act like a single 8 pin cable or would I need to order two single 8 pin cables?
You are pulling more than the recommended 150 watts from the cable.
To see what you are using per cable use GPUZ under sensors.
Looks like this. I have the ROG Strix OC 3080 and it can use over 450 watts so it uses 3 cables.
The last time I daisy-chained was with my GTX 980 ti(1 8pin and 1 6pin) SLI setup. One of the cables eventually shorted and took out a video card. Fortunately there was 45 days left on the warranty and to my surprise EVGA replaced it.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
Yes that is perfectly fine. I would just tie the lose end, with the other 8pin, to the cable so it looks cleaner and doesn't dangle around. You don't need to get extra cables that don't have the daisy chain ability.
Desktop: i9-10850K [Noctua NH-D15 Chromax.Black] | Asus ROG Strix Z490-E | G.Skill Trident Z 2x16GB 3600Mhz 16-16-16-36 | Asus ROG Strix RTX 3080Ti OC | SeaSonic PRIME Ultra Gold 1000W | Samsung 970 Evo Plus 1TB | Samsung 860 Evo 2TB | CoolerMaster MasterCase H500 ARGB | Win 10
Display: Samsung Odyssey G7A (28" 4K 144Hz)
Laptop: Lenovo ThinkBook 16p Gen 4 | i7-13700H | 2x8GB 5200Mhz | RTX 4060 | Linux Mint 21.2 Cinnamon
