Warzone Stuttering with Ryzen 3700 and RTX3070
Solved by XVB,
14 hours ago, Ataulf said:So I ran the Windows Memory Diagnostic tool and the report came back clean. However, I did have to bump up the frequency on the RAM to 3600 manually to match the speed that was on the box, so it's possible that I got a bad kit. I'll try dropping it back to 3200MHz and see if that resolves the issues.
I don't think it's the monitors. I've got a triple monitor setup (2x 1080p 60hz ASUS + 1x 4k 120hz LG OLED) and the stuttering occurs on both the OLED and the 1080p monitors.
Warzone is installed on a PCIE Gen4 NVMe SSD. I believe NVIDIA reflex is on. I think I was also getting the stutter in SplitGate.
That is a clear problem of the ram not up to spec
