Hey, my pc just crushed fans went to 100% pc turned off it said smth happened i mangaed to fix it, after fixing it it asked me to redo my windows 10 password.
now it wont detect my headphones and other headphones i tried, i also connected the case audio to the motherboard port and it is still getting no single any idea why.
do i have to buy an aux to usb for it to work ?
https://linustechtips.com/topic/1369959-hey-my-pc-audio-doesnt-work/
Go to Sound > Playback and check which device is being used as your main audio output. If something ever happened to my PC, that stuff for some reason kept resetting onto my monitor as an audio output which doesn't even have speakers.
Just added this so in case I run into some issues, there's detail about my PC right underneath
PC 1
CPU: Ryzen 7 5800X3D | GPU: RTX 3070 | RAM: 2x8GB DDR4 3200mhz | Motherboard: TUF Gaming B450-M Case: Deepcool CC560 | Cooler: darkflash 320mm AIO | PSU: Antec 1000w HCP Platinum
PC 2
CPU: Xeon W3680 (4.41ghz OC) | GPU: MSI Vega 56 Airboost OC | RAM: 20GB DDR3 1600mhz | Motherboard: Asus P6T Case: Zalman R1 | Cooler: Deepcool GAMMAXX GT A-RGB | PSU: Thermaltake Berlin 630w 80+ Bronze
i have tried that
it is only showing this nothing else and those are my monitor
2 minutes ago, NinJake said:
Have you tried any other audio devices to see if those are detected? Ensure your audio drivers are up to date? Windows is up to date?
i have tried 2 different headphones, both work on my phone or laptop but on the pc nothing. i also tried plugging the headphones through my monitor and through my pc case aux and motherboard aux
but nothing
5 minutes ago, NinJake said:
Do you have a spare USB drive?
EDIT: before we go into a live linux USB, have you verified your windows is up to date and you have the latest audio driver provided from your motherboard manufacturer? @Lia_owo
it is up to date i also updated everything about the amd cpu
i have an msi motherboard but idk how to update it
and i have a spare usb drive yes
Looks like the integrated audio isn't being detected.  Open old school control panel (hold windows key and press R then type control and hit enter.  Open device manager  and see if there are any exclamation marks on any parts or even if the sound card is in there at all.  If not you may need to enter uefi/bios and make sure it''s enabled in there
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
image.png.f812ee91fab5edf7ff5863b045fded79.png.
there is nothing here it seems, btw when my pc crushed it seems that all the drivers did a run back and needed to be updated when i tried to download the realtek audio driver after restarting my pc and all it wont show up as installed and when i press on it it wont react like nothing happens
i tried two times alraedy
How are you installing the driver for audio device?   Through windows or from motherboard website?  Either way you need to install from website for best results.  Before doing that download DDU-extract to desktop-restart in safe mode. (Windows+R, msconfig,  click boot tab and select safe mode, restart when prompted) Open DDU after restart and remove realtek with clean and restart.  THEN install the audio drivers from your motherboard makers website
You can try to use your spare USB to create a bootable linux system. Read here -> https://ubuntu.com/tutorials/create-a-usb-stick-on-windows#1-overview
Once that's complete you boot from the USB instead of windows on your hard drive, once you're in the Ubuntu Distribution you can test if the audio is working. If so, you know for a fact it's an issue with your audio drivers in windows. If it still doesn't work, it could be a larger problem and may need to RMA your mobo for instance.
so many words i dont understnad hh i will attempt, since i work from home if i dont get it done by tonight i have to buy a usb to aux do you think it would work ?
i just tried DDU still nothing, ngl im feeling a little lost. do you think usb might help im extremly tired and i got work in 5 hours
i didnt try linux sorry im too tired and it would take at least a hour for me
Yeah,  don't worry about Linux just yet.  Get some sleep.  A little usb sound card will work a treat until you troubleshoot your main audio hardware
i didnt sleep yet some guide said to use msconfig and then my i found my self locked out of my pc with internet disabled, so i quick restarted the windows and all. i got an ssd so it was quite fast
i noitced that after downloading again all the drivers Realtek networking is working i can find it in device manager but Realtek audio is not no matter how many times i delete and downlaod it
do you make know of a replacment ?
