Hi! This is just a small question on what do you think about my current build and if there are some major handicaps. And maybe some suggetions on what to upgrade.  I wanted to buy myself an m.2 SSD aswell and would like to ask for some options.
Primarily used for Gaming and a lil Rendering with After Effects and Photoshop
I have no set Budget but would look for mid range stuff
I only have connected one AOC 144hz Gaming Monitor via Display Port
CPU: Ryzen 5 2600 @ 3.85Ghz
GPU: Msi Radeon RX 5700 XT Mech OC ( 2000mhz Clock and 1860mhz Vram)
Ram: 2 x 8Gb DDR4 G.Skill Ripjaws V 3200mhz
PSU: BeQuiet! PurePower 500w
Mobo: ASUS PRIME B450 Plus
Drives: 500GB Intenso SSD , 1TB Toshiba HDD
OS Windows 10 Pro
Edited by Strivey
https://linustechtips.com/topic/1369958-advice-critic-on-current-pc-build/
CAn you tell us what your machine is used for?  Work, games, editing, etc?
What's your budget and location?
There is a template in the "Read First" thread in this forum, please follow that.  It helps us suggest things.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Is your computer having any problems with the current games or program you're using? Build looks relatively balanced to me.
Only thing I would consider upgrading to is a 3700X, as they are pretty good deal right now. Also opens up the PC for multitasking which is super liberating experience when you start doing it :D. Not having to close all my programs to game is very nice.
The 5700XT is still a very capable card today so I'd probably hold on to it until rtx 40 series and AMD 7000 series launches.
More RAM? That's a pretty easy upgrade. Only would recommend it if you do multitask a lot.
Some m.2 SSD's you can consider:
See used market prices for 5700XT and 6700XT. Since the first is great for mining, and latter pretty bad, you could upgrade really cheap, or even for basically free.
Then, if you play CPU-heavy titles at 1080p, you could consider CPU upgrade as well.
If i were to upgrade to a Ryzen 7 3700x i should upgrade Cooling aswell since i have been Using the Stock Cooler for my Ryzen 5 and he keeps getting a bit too noisy for me when playing Games like CSGO. Also it seems like i just noticed but AMD states that the 2600 only supports Memory speed up to 2933mhz but i have mine set to 3200.
Yeah, that's called memory overclock, and it's totally normal to do this.
CSGO is also pretty cpu bound, so that is probably worth upgrading cpu for. Your motherboard should support Zen 2 CPUs as well.
The 3700X does come with a stock cooler which is enough to keep it cool. I do hear it is quite loud though. You can look into an after market cooler if you want a quieter cooler. You can check out Noctua NH-U12S, Scythe Mugen 5 or Scythe Fuma 2. They are all good options.
I added the Corsair psu, if you feel like you want to change that. If you're overclocking anything other than the RAM, you definitely should upgrade that. If not, you should still be okay with that 500W psu, but I would recommend upgrading that too.
Definitely double the RAM, if you have room in your budget for it. Recommend getting the exact same kit, if you can.
https://pcpartpicker.com/list/8YkGp2
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($289.99 @ Adorama)
CPU Cooler: Noctua NH-U12S redux 70.75 CFM CPU Cooler  ($49.95 @ Amazon)
Motherboard: Asus TUF B450-PLUS GAMING ATX AM4 Motherboard  (Purchased For $0.00)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive  ($79.98 @ Amazon)
Storage: Western Digital Blue 1 TB 2.5" Solid State Drive  ($94.99 @ Amazon)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Newegg)
$629.90
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
