PLEASE HELP is my cpu ok?
Go to solution Solved by Parzival120,
5 minutes ago, Mel0nMan said:
This is the exact same post from a few days ago is it not?
Yes. It's absolutely fine.
What the I have no idea how this got posted again
so i am building my first pc and i was opening up my 5600X and i was trying to open up the clamshell and it was being a little bit difficult to open up so i tried harder and i got it to open but when it opened it popped up a little bit and one of the corners of the cpu was resting on the side of the clamshell. it wasn't like a big part of the cpu it was just the little corner. i started to freak out and i was worrying like what if i bent a pin or what if a pin came off. i looked at the pins and i didnt see any bent pins or missing pins but im just SUPER worried. Do you think my cpu is ok? i will post pictures of the pins. Thanks and please tell me if you think its ok
IMG_3117.thumb.JPG.7691e3d7e10f0474dd32038ca78495bf.jpeg.6421c0bcb4b504fce375695c33e15f38.jpeg
IMG_3110.thumb.JPG.4f5fe738912ccd3db81fd560e1c2e114.jpeg.c1d0cfbaab8ea120f6afa1deecc03311.jpeg
IMG_3109.thumb.JPG.71f06268e2f4aa11c4cecb07788abde5.jpeg.23261f20d8461f88067e9c943d5fc56b.jpeg
https://linustechtips.com/topic/1369163-please-help-is-my-cpu-ok/
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
<-- Thread Locked -->
Please continue this in your existing thread regarding this:
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Guest
