So I have the deepcool RF120 fans in my case but no RGB header on motherboard so I'm forced to use the remote however would like to use software if possible. I Have been looking at controllers to do so but I don't think this one will work with other brands https://www.coolermaster.com/catalog/coolers/rgb-accessories/rgb-led-controller/ . The fans are 12V Rgb
https://linustechtips.com/topic/1369156-rgb-help/
that will work if your fans are rgb
https://linustechtips.com/topic/1369156-rgb-help/#findComment-14960925
This is correct. You would just need to plug the last fan of the daisy chain into the sync cable, then plug the sync cable into one of the connectors of that controller. Make sure you have the 12v pin lines up on the sync cable and the connector from the controller. From there, you would just download CM's MasterPlus software and control the lighting from there.
Regards,
Nguyen
https://linustechtips.com/topic/1369156-rgb-help/#findComment-14962429
