water cooling question
Go to solution Solved by For Science!,
you do not need it
water cooling is only marginally better than air cooling when for hardware like this, most people go for water cooling mainly for looks.
i would get an AIO cooler for the cpu because it looks nicer than any air cooler and leave the gpu as is.
but yeah as the guy above said you really don't need it
https://linustechtips.com/topic/1368635-water-cooling-question/#findComment-14957311
